Announcement
No announcement yet.
Problems with BurnInTest 8.1 Build 1012
  • Filter
  • Problems with BurnInTest 8.1 Build 1012
    So we have been testing BurnInTest 8.1 Build 1012 and have found two major problems.
    1. The Networking section of the system information tab will only show 1 network device, even if there are multiple devices installed in the system. I confirmed this behavior is NOT OS specific, this does not occur in BurnInTest 8.0 Build 1024. This is a problem because the test certificate only shows 1 network device.
    2. The DirectX DLL files that are included on the USB install are BOTH 64bit, so when testing with a 32bit OS the 3D tests fail, this did not occur in BurnInTest 8.0 Build 1024.
    We are also experiencing stability issues when running the GPGPU tests.
  • #2
    The networking information will be fixed in the 1013 build (now available here).
    Previously only the 32bit DLLs were included with the installer, now both 64 and 32 bit versions are however only the appropriate set is installed. We'll change the installer for 1013 to include both sets.
    What sort of stability issues? Are you using the latest available driver for you video card?
    Last edited by Tim (PassMark); Mar-23-2016, 02:41 AM. Reason: Update for download link
