Running BurnInTest ARM Linux v5 on Ubuntu 24.04 (ARM64)
  • AdamGao
    • Jun 2025
    I am currently trying to run BurnInTest Linux ARM v5(command-line version: `bit_cmd_line_aarch64`)
    on Ubuntu 24.04.2 LTS (ARM64 architecture). The software launches but immediately crashes due to a missing `libtinfo.so.5`.
    Since `libtinfo.so.5` is not available via `apt install` under Ubuntu 24.04, I manually downloaded the `.deb` package for `libtinfo5` (version 5.9), extracted it, and copied the `libtinfo.so.5.9` binary to `/lib/aarch64-linux-gnu/`.
    I also created a symbolic link named `libtinfo.so.5`.
    However, after doing this, the program now crashes with a **segmentation fault**.
    Could you please advise:
    1. What packages or libraries are required to successfully run BurnInTest v5 for Linux ARM on Ubuntu 24.04 ARM64?
    2. Is BurnInTest officially compatible with Ubuntu 24.04?
    • 11114
    Supported platforms are on this page
    https://www.passmark.com/products/bu...m_download.php
    At the moment the list is,
    • CentOS 7
    • Fedora 32
    • Ubuntu 16.04, 18.04, 20.04
    • Raspberry Pi OS
    • Linux 4 Tegra 32.4
    ​but we are probably due to update the list.
      • 11114
      Details are on this page to install libcurses5 and resolve the libtinfo5 error.
      https://www.passmark.com/support/bitlinux_arm_faq.php
      Ubuntu 24.04/25.04 ​have now been tested and are supported (once libcurses5 is installed).
