We have a report from testing BURNInTEST Version 11, Build 1013 with the ParallelPort test,
Parallel port test fails and returns error 64 stating "Could not detect the parallel port selected" when testing on Windows 11 with HVCI (memory integrity protection) enabled.
Parallel port test fails and returns error 60 "Error loading Parallel port device driver. Check administrator privileges." with HVCI disabled.
The application is always run with Administrator privileges.
The operating system is Win11 IoT Ent LTSC 2024.
The base hardware is using the Advantech PCE-5132. The physical parallel port is sourced from an NCT6776D Super I/O on the LPC bus. Other functions used from this device (such as Serial Ports and H/W Monitor) work fine.
