System Freezes During Burn In Test
  • Ginger1993
    • May 2016
    Dear Experts,
    Performed BurnIn Test (64-bit) V8.1 Pro (1009) on 12-Apr-16 8:27:54PM on Dell Latitude E5470: i7-6820HQ (Quad Core, 2.7GHz, 8MB cache), 512GB Samsung SSD (WAVE-encrypted), 2x8GB 2133MHz DDR4 Memory, and Integrated HD Graphics 530 only.
    System hanged after 8hours 49mins 8s of BurnIn Test. Laptop display stayed at 13-Apr-16 5:17AM when I visited the machine at 13-Apr-16 8:24AM. Mouse and keyboards were not responsive at all. Had to perform 4s Power Shutdown. The frozen GUI displayed information as below:
    1. 3D Graphics - 70 cycles - 2.121Million - 0 Error
    2. Advanced Net - 207 cycles - 223Billion - 2 Errors - Unable to connect to Endpoint
    3. CPU - 1143 cycles - 99.19Trillion - 0 Error
    4. Disk(C) - 947 cycles - 10.31Trillion - 0 Error
    5. GPGPU - 1045 cycles - 263Trillion - 0 Error
    6. Memory (RAM) - 865 cycles -17.046Trillion - 0 Error
    7. OpticalDisk(E) - 28 cycles - 245Billion - 0 Error
    8. Serial Port 1 - 987 cycles -56.901Million - 0 Error
    9. Temperature - (100C Threshold) - 0 Error
    10. USB3 - 84 cycles - 2.778Trillion - 0 Error
    There was only 1EA e1dexpress error logged at 12-Apr-16 5:15:14AM in the Event Viewer during BurnIn Test period. e1dexpress states that "Ethernet connection I219-LM Network link is disconnected". Unexpected shutdown was recorded to happen at 5:16:10AM.
    Nonetheless, able to successfully execute 12hours BurnIn Test for a total of 3 times now on the machine and no error is found. My question is how do I figure out what are the possible causes to the past event of system freeze?
    Freezes are hard to debug. Could be bad hardware, could be bad device drivers, could be some random external event (power spike, EMI, etc..)
    If the problem isn't reproducible then I don't think you are going to be able to find the cause.
    If you can reproduce the problem, then there are some other options, like narrowing the problem down to just a specific test (e.g. just the 3D test), or running a remote kernel debug session via a null modem cable if the lock up is in the O/S.
