NPU test error with BIT 11.0 _Intel Pather Lake
  • Sharon
    • Aug 2016
    • 32
    Hi Team,
    We encountered the following error on Intel Pather Lake ES2/EV QS CPU samples when running BIT V11.0:
    No NPU adapters detected or adapter not supported
    For reference, we also tested BIT v11.0 on Intel Meteor Lake, Intel Arrow Lake, and Intel Lunar Lake, and all returned Pass results.
    As Intel Pather Lake is still in the development phase and not yet in mass production, could you please advise when the BIT tool will be updated to support Intel Pather Lake CPUs?
    Thank you for your support.
    Sharon Li
    We do not get advance/pre-release hardware, but the NPU Test uses OpenVINO for testing and the detected NPUs are from querying the OpenVINO SDK. If the NPU is not showing up, then make sure you have the latest Intel NPU drivers.
    • Sharon
      • Aug 2016
      • 32
      Copy that, we can see the Intel NPU devices in device manager , and also we can get the throughput data using OPENVINO for testing, thanks for your reply.
