What Does ThresholdPer Pertain To and How Should It Be Used?
  • adabney
    • Sep 2025
    I'm coming across a parameter or reference called ThresholdPer in the configuration file: cmdline_config.txt and would like to understand its purpose.
    • What does ThresholdPer refer to?
    • In what context is it typically used?
    • How should it be configured or interpreted?
    Any clarification or examples would be greatly appreciated.
    ThresholdPer is a setting for the Battery Test. The value is percentage threshold for when an error is logged, eg 90%. If the measured value (full charge or current charge) drops below this level when compared to the battery's design capacity an error will be logged.
    Refer to the BurnInTest Linux User Guide for the various settings and their definitions.
