BIT ARM - Unable to open sound device
  • manolo-mm
    • Oct 2025
    • 14
    Hello
    I'm currently trying out BIT for ARM and so far its working quite well but I ran into a wall with sound. No matter what I configure I always get this error message:
    Click image for larger version  Name:	image.png Views:	0 Size:	22.3 KB ID:	60008
    I tried SoundDevName plughw and default​
    aplay -l shows
    card 0: wm8904audio [wm8904-audio], device 0: HiFi wm8904-hifi-0 [HiFi wm8904-hifi-0]
    Subdevices: 1/1
    Subdevice #0: subdevice #0​
    I tried all devices names with the same result.
    Do I miss something?
    Can you run BurnInTest in debug mode, using the command line parameter "-d"? Then send us the debug.log file that is created after the issue is reproduced.
      Linux has been trying to get sound working for over 30 years​, still hasn't happened
