BurnIn test V8.1 Pro for WWAN/LTE
  • rachelchiu1998
    • Jun 2016
    Hi
    I would like to test Network function via mobile broadband.
    But it seems the Burnin Pro can not detect the device as one of Network connection options
    Is there any way, we can test stress test on LTE
    Kindest Regards,
    Rachel
    The network test in BurnInTest can work on any TCP/IP network.
    So if you can, for example, browse the web via your network connection, you should be able to run the network test. The physical network (radio, wires, optical) doesn't matter.
