NPU test error with BIT 11.0 _AMD Gorgon Point
  • Alexxxx
    • Jan 2026
    • 15
    Hi Team,
    We encountered the following error on AMD Gorgon Point Ryzen AI 7 PRO 450 APU samples when running BIT V11.0:
    No NPU adapters detected or adapter not supported
    Our NPU version is 32.0.203.311 and the error pops up once the test starts
    Attached is the debug log, please help to check if anything wrong.
    Thank you for your support.​​
    The NPU Test in BurnInTest uses OpenVINO. OpenVINO is designed specifically to optimize and run inference on Intel hardware, as of this post, it does not officially support or provide plugins for AMD Gorgon Point NPUs, which are based on AMD XDNA architecture.
    We do not have an estimate of when AMD NPUs will be supported in BurnInTest, but we are looking to support AMD NPUs in future releases.
    • Alexxxx
      • Jan 2026
      • 15
      Got it, thanks for the support
        BurnInTest Version 11.1 build 1001 (30/July/2026) now has support for NPU testing on AMD CPUs.
        https://www.passmark.com/products/bu...st/history.php
