A info about COM RS485
  • paolo.moro
    • May 2018
    • 77
    Hello!
    • Does the Serial Port test module support RS485 — half-duplex, differential signal lines?
    • How does it handle bus direction control — via RTS signal, via a dedicated pin, or automatically?
    • Does it require a physical loopback connector, or does it support a port-to-port test mode (two RS485 ports connected to each other)?
    thanks
    I had this RS485 question 23 years ago.
    Situation hasn't changed from 20 years ago. Half duplex probably won't work, at least not without some special adapter.
    • paolo.moro
      • May 2018
      • 77
      Uao...
      It's been a while... I'll try using a null-modem cable for the test. Let's see how it goes.
        It is probably possible to make it work, but no one was ever prepared to paid the development costs involved (and RS485 was never very common, even 20 years ago).
