USB Setting Not Staying Selected
  • zenmota
    • Sep 2014
    • 216
    If I go to BurrnIn Preferences then USB, under Check Bus Errors and select Generate a Log For Every Low Level Error and Save it, it does not stay always goes back to Generate a Log Error When Low Level Errors Are Above Specified Ratio. BurnIn Test Version 11.1 (1000). Screenshot attached.
    Looks like it is a bug related to recent addition of USB error rate measurements and USB-C 20Gbit support.
    It will be fixed in the next patch release.
      This should be fixed in BurnInTest Version 11.1 build 1001 (30/July/2026) .
      https://www.passmark.com/products/bu...st/history.php
