BIT crashed
  • manolo-mm
    • Oct 2025
    • 14
    BIT crashed
    Hello
    I did a 72h test and Burnin crashed after two days. There was a crash report in the windows event manage (see text file) but I think the reason for the crash could be that the log file sizes where quite large. Thy contained almost exclusively temperature warning from the 22 CPU cores. I did not have the temperature test tab active but it seems that temperature logging is active by default. (v11.0 build 1021).
    Please check the win error and tell me if my suspicion is right. Please deactivate temp logging by default in future releases or at least make a limit on the amount of log entry's created.
    BR Manolo
    BurnInTest crashed due to an access violation (0xc0000005). This does not explicitly indicate the issue is with large text files. There were several updates since the version/build you are using. https://www.passmark.com/products/bu...st/history.php
    Try updating BurnInTest to see if any changes. If there was a crash dump generated using the latest release, zip it up and send it in and we can analyze it to determine where the crash may be occurring.
