BIT Linux ARM CTS Stuck Low w/ DisableCTS Set
  • PXCScott
    • Aug 2021
    • 12
    Running V5 (1027) ..
    I have RTS / CTS / DSR / DTR disabled (I think)
    Relevant Serial port section from cmdline_config.txt
    Code:
    ## Device to test - ttys0, ttys1 etc to ttys63
    Device ttymxc0
    ## Test Mode - Loopback or Detect
    TestMode Loopback
    ## Disable RTS/CTS and DSR/DTR
    DisableRTS
    DisableCTS
    DisableDSR
    DisableDTR
    ## Send and receive timeout, 100-30000 ms
    #SendReceive 3500
    ## Baud rate - 110, 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200,
    ## Cycle to 115200 (Cycle115), 230400, Cycle to 230400 (Cycle230), 460800,921600
    BaudRate 115200
    </Serial>
    Log entries
    Code:
    DETAILED EVENT LOG
    LOG NOTE: 2026-11-04 15:51:27, Disk: Hard Disk (/run/media/mmcblk2p2) [/dev/mmcblk2p2], Each file size is: 63 blocks of 16384 bytes (0 MB, 1032192 Bytes)
    LOG NOTE: 2026-11-04 15:52:02, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:52:02, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:52:38, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:52:38, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:53:13, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:53:13, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:53:49, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:53:49, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:54:25, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:54:25, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:55:01, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:55:01, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:55:36, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:55:36, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:56:12, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:56:12, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:56:48, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:56:48, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:57:23, Serial Port: ttymxc0, /dev/ttymxc0: CTS stuck low
    SERIOUS: 2026-11-04 15:57:23, Serial, COM port Clear To Send (CTS) line stuck low
    LOG NOTE: 2026-11-04 15:57:55, Status, Test run stopped
    Why is it trying CTS when I have DisableCTS.
    NXP i.MX8MP with Yocto and Linux 6.12.3-lts-next-g37c02b8bfb4
    • 333
    Note that 'DisableRTS' will disable RTS+CTS and 'DisableDSR' will disable DSR+DTR
    Might just be missing your excerpt, but each device should be in its own <Test> tags as well
    Code:
    ## Serial Port - Have a <Test> section for each device to test
    <Serial>
    <Test>
    ## Device to test - ttyS0, ttyS1 etc to ttyS63
    Device ttyS0
    TestMode Loopback
    </Test>
    ## Disable RTS/CTS flow control testing
    DisableRTS
    ## Disable DSR/DTR flow control testing
    DisableDSR
    SendReceive 3500
    BaudRate 115200
    </Serial>
    If it still does not work, can you run in debug mode (with '-d' parameter), reproduce issue, and send the generated debug.log file as well as your entire cmdline_config.txt
