If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
3D Graphics test fail: Unexpected error running DirectX 12 Test.
Hi Passmark member
We running Burn-In test on EHL platform on Win10
Error code: 0x887A0005 (-2005270523)
And met 3D error , log as attache file
Could you share if any comment on this symptom?
Error was this:
SERIOUS: 2026-11-04 15:47:56, 3D Graphics, An error occured during the DX12 3D test
LOG NOTE: 2026-11-04 15:47:56, 3D Graphics, Unexpected error running DirectX 12 Test. Error Number 0x887A0005 (-2005270523)
LOG NOTE: 2026-11-04 15:47:56, 3D Graphics, GPU foCX CX^Xªf³êĢܷB GetDeviceRemovedReason ðgpµÄKØÈANVðmFµÄ¾³¢B
LOG NOTE: 2026-11-04 15:47:56, 3D Graphics, DXGI_ERROR_DEVICE_REMOVED (0x887a0005) - Device Removed reason: DXGI_ERROR_DEVICE_RESET (0x887a0007)
Details:
0x887A0005 is the DirectX Graphics Infrastructure / DXGI error: DXGI_ERROR_DEVICE_REMOVED
The error comes from the device driver.
So the application did not necessarily “remove” the GPU physically. It means the DirectX device handle became invalid because Windows/DirectX considered the graphics device removed or reset. The DX12 graphics device was lost/reset, most commonly due to a graphics driver crash/reset or GPU timeout during the test.
The 2nd code, means more or less the same thing
You might find more details in
Windows Event Viewer
Check Windows Logs → System
In short: The GPU (or it's device driver) crashed.
