two questions about burnintest linux vision
  • realmadrid
    • Apr 2007
    I download burninlinux version and use it well, now I really want to buy a copy, but at first, I have two questions 1. can I run linux version in command line mode, using the parametre -c, -r , just like in the windows version 2 can I run the program automatically in linux, I mean can the program bootup, exit, and save the test result automatically ? ( just as it can do in windows)
    pls reply, thanks
    Yes in release V1.0 (build 1004) - 09 March 2006, we added the "-R" (or "--autostart") and "-C" (or "--config") command line options.
    -R: (no argument)
    Auto start without needing to press "Start Test".
    -C: (argument needed)
    Determines which config file to use.
    Example:
    burnintest -R -C testall.cfg
    burnintest --autostart --config=testall.cfg
    • realmadrid
      • Apr 2007
      but the programe can not exit itself,right?
      but the programe can not exit itself after the test is finished, right?
      ( if it can exit itself, I can write a shell file easily to shutdown the computer after the test)
        I haven't tested it today, but I believe, from memory, you are correct.
