V2.1, s-ata drives showed twice
  • PassMan
    • Dec 2006
    • 12
    My 2 s-ata drives are showed twice, as normally and as SCSI Disk Devices. I got XP SP2.
    How do they appear in Windows device manager?
    Are they connected via the motherboard SATA interface or a PCI card or via some other interface? Are you running software or hardware RAID? Do you happen to know if the previous release (V2.0) has the same behaviour?
    • PassMan
      • Dec 2006
      • 12
      They appear as SCSI Devices.
      They are connected to MB sata connectors. I got software RAID from VIA.
      Was 2.0 that 1004 Build? If yes, there was no problem.
      • PassMan
        • Dec 2006
        • 12
        Is it normal that SATA drives are detected as a SCSI frives?
