stresstest
  • harryo
    • Mar 2008
    stresstest
    I downloaded and installed StressTest but it will not run on my computer. How do I delete it, I can't find it anywhere.
    Thankes,
    Harryo
    StressTest was a custom version of our BurnInTest product that we did for Intel, but it was restricted to working on a certain set of Intel motherboards. So you might want to try BurnInTest instead.
    You should be able to uninstall it from the Windows control panel like all other Windows software.
    • harryo
      • Mar 2008
      StressTest
      What do I look for to delete this apps. I do not find anything that says StressTest.
      Thank you for your help,
      Harryo
        I am not sure how Intel bundled it in the end. So it might uninstall when you uninstall the rest of Intel's utilities. You could also just delete the files from the program files folder.
        If you can't find it and it isn't in the uninstall list then maybe it is no longer installed.
