Suggestion for DiskCheckup
  • Largo
    • Apr 2008
    Please make the [X] option to just minimize it and NOT shut it down !!
    What do you mean?
    Specifying the, Configuration->Minimize to system tray option, means that when you select minimize Window, the software will go into the System tray rather than to the Taskbar. It does not exit.
    We need to add this to the help file.
    Ian
    • Largo
      • Apr 2008
      I mean that it is very easy to select [X] instead of [-] and shut down the software.
      [X] should be DISABLED or modified to minimize and NOT shut down.
      Like SKYPE.
      • Largo
        • Apr 2008
        ...not to mention .... Start With Windows option.
        Pitty such a nice software missing those things ....
        Cheers from Athens, Greece !
          We have added these comments to the list of possible features for the next version of DiskCheckup.
          Ian
