sleeper test
  • testlog
    • Mar 2008
    • 32
    sleeper test
    i check the S1 mode and click the sleep button. 100 cycles is applied
    system goes into standby
    i need to press power button to wake it up, then the second cycle will continue.
    is that correct? so the test doesn't run automatically?
    If you have set a reasonable sleep duration (e.g. 60sec), and don't select the Sleep Forever option then the machine should wake itself up.
