Youruninstaller Fixclock Problem
  • tcmiles53
    • Apr 2009
    I upgraded my YourUninstaller Program. I am getting the message “Your system clock appears to have been changed, possibly in an attempt to defeat the security system on this program. Please correct your system clock before trying to run this program again. If your clock is already correct, rebooting the system may fix this problem, otherwise contact the author of this program for instructions. I sent an email for an unlock code, but not sure if it made it thru. Thanks in advance.
    TCM
    • 11115
    This forum is for the support and discussion of software and hardware from PassMark.
    We have never heard of, "YourUninstaller". It is not our software. If you have a problem with this software you should contact the author. If the author doesn't provide any contact details, which is typically the case for products like this, then you should just get a refund and be more careful from whom you purchase from in the future.
