Procedures for Installing DiskCheckup Program
  • scams
    • May 2009
    I have a Dell Dimension 8200 computer with windows XP Pro (SP3) installed. Also installed is the DiskCheckup program (ver 1.1, build 1003)
    I have download the later version (ver 2.1/build 1004) for install. Should I uninstall the existing DiskCheckup program first, or is it okay to install the newer version on top of the existing version?
    If I need to uninstall the existing program, how do I accomplish this function? I did not see any uninstall entry in the Add/Remove list and did not see any uninstall entry in the Start/All Program/Passmark DiskCheckup entries.
    Thanks for any help, Sam.
    Yes, you can just install it over the top.
    • scams
      • May 2009
      Thanks very much for your reply, Sam.
