Video card suggestions?
  • shotgunbob
    • Jul 2009
    Well I wanted to get this one HP computer until I learned its Nvidia 9100 GS was incredibly weak, theres another computer with a Nvidia GT 220 and its score on this site says its a mid range high end card, Would you suggest getting the one with the GT 220 or buying the one with the 9100 (whitch is cheaper.) and upgrading to a 9800 or atleast a decent 8 series?
    Depends on the intended use of the machine.
    Also make sure the machine is in fact upgradeable. Some of the small form factor machines have limits.
    • shotgunbob
      • Jul 2009
      Generally for gaming, Mainly for Flight Sim and a few others
      I also plan on getting Modern Warfare 2 if my new omputer can handle it
        It would make sense (to me) to get a machine with the parts you want. Rather than buying a machine with a graphics card that you are never going to use.
        I don't think you are going to be happy with either the GT 220 nor the 9100 GS if you are a gamer. but it depends on your budget as well.
