Sleeper & Turn off Monitor
  • bryan chan
    • Nov 2009
    Hi, I need your help about Sleeper App.
    With Control Panel\Power Options\Change Plan settings, I set Turn off the monitor is never, then run S4 by Sleeper.exe for some cycles. the item Turn off the monitor will become the default setting "after 20mins". But I wanna keep it never, how can I do? Thanks!
    Sleeper doesn't make any changes to the this Windows configuation setting. At least not directly.
    • bryan chan
      • Nov 2009
      All right, I'll check if the other software cause the issue or not. Thanks for your explanation!
