WMPF file conversion
  • vfarrell
    • Jul 2011
    How can I convert the project file to a user friendly format so I may send the file to a client who does not have the wirelessmon software. Is there a viewer available or a conversion suggestion.
    Thank You
    Victor
    • 11112
    If they need to see the whole project and not just a screen shot or print out, then I would suggest they download the trial WirelessMon software.
    • vfarrell
      • Jul 2011
      Wmpf
      Actually I installed Adobe Pro and printed it to a pdf file and it is scalable and clean and works fine.
      thanks for the response though.
      victor
