v7 error install on XP Pro SP3
  • gufus
    • Sep 2011
    • 8
    I'm having problems installng v7 of Burintest Pro on my XP Pro SP3 system.
    Here is the error mssage:
    http://www.gypsy-designs.com/1.jpg
    <?xml version="1.0" encoding="UTF-16"?>
    <DATABASE>
    <EXE NAME="bit.exe" FILTER="GRABMI_FILTER_PRIVACY">
    <MATCHING_FILE NAME="bit.exe" SIZE="7059200" CHECKSUM="0xE4DA7155" BIN_FILE_VERSION="7.0.1002.0" BIN_PRODUCT_VERSION="7.0.1002.0" PRODUCT_VERSION="7.0.1002.0" FILE_DESCRIPTION="BurnInTest" COMPANY_NAME="PassMark Software" PRODUCT_NAME="PassMark BurnInTest" FILE_VERSION="7.0.1002.0" ORIGINAL_FILENAME="bit.exe" INTERNAL_NAME="bit" LEGAL_COPYRIGHT="Copyright © 1999-2011" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6C97C1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="7.0.1002.0" UPTO_BIN_PRODUCT_VERSION="7.0.1002.0" LINK_DATE="09/22/2011 06:50:44" UPTO_LINK_DATE="09/22/2011 06:50:44" VER_LANGUAGE="English (Australia) [0xc09]" />
    <......snip.........>
    <MATCHING_FILE NAME="kernel32.dll" SIZE="989696" CHECKSUM="0x2D998938" BIN_FILE_VERSION="5.1.2600.5781" BIN_PRODUCT_VERSION="5.1.2600.5781" PRODUCT_VERSION="5.1.2600.5781" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.5781 (xpsp_sp3_gdr.090321-1317)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFE572" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.5781" UPTO_BIN_PRODUCT_VERSION="5.1.2600.5781" LINK_DATE="03/21/2009 14:06:58" UPTO_LINK_DATE="03/21/2009 14:06:58" VER_LANGUAGE="English (United States) [0x409]" />
    </EXE>
    </DATABASE>
    By the way..
    V6 Pro installed fine, but I just bought a V7 licence
    Thank you for purchasing from PassMark Software.
    IMPORTANT: You will find the license keys for your software items below in this e-mail.
    Order number: WP5AU45680
    Date: 29/Sep/2011
    You have ordered the following item(s):
    BurnInTest Professional Upgrade (Qty: 1): $39.50
    Kevin Klement
  • Meryl (PassMark)
    • Feb 2011
    • 12
    Please use the command line parameter -U to enable debug logging for BurnInTest. For examples see the Help file, under the heading "Command line arguments (other BurnInTest options)".
    Please send the debug file to us at
    help [at] passmark [dot] com
    Meryl
    • gufus
      • Sep 2011
      • 8
      Meryl
      Hi Meryl,
      Okay.. I will ASAP.
      Kevin
      • gufus
        • Sep 2011
        • 8
        debug log file
        Hi Meryl..
        I sent my debug log file.
        -K Klement
          This problem is resolved in Public release 7.0.1003.0005 available here:
