What gfx card best suits to my config.
  • Preetesh
    • Feb 2012
    I ve following config. bt m confused to select gfx card best suits to it for gaming ......just to avoid bottleneck....
    Processor: intel i5 2500k
    RAM : 4gb
    Motherboard: intel DH67cl media series
  • wonderwrench
    • Oct 2007
    • 264
    What are you going to use the PC for? Unless you are a gamer the GPU integrated into the CPU will be fine. If you are a hard core gamer the more money spent on the GPU the more performance you will get in games. 4gb's of ram is on the low side for a new PC running a 64 bit OS.Really low if your a gamer. With the low ram prices I'd go 8 or 16 gigs on any new build.
    Bill
      Depends a lot on your budget as well. If you can afford it and you have the power supply for it, then look at these cards (for Feb 2012),
      GTX 580
      GTX 570
      GTX 470
      Or
      Radeon HD 7970
      Radeon HD 7950
      Radeon HD 6990
      Radeon HD 6970
