which system should I get
  • nextlevel
    • Sep 2012
    I have too buy another laptop my needs are as followed
    I am a Hyperion Essbase and Planning Developer and I DJ and produce music and do home recording.
    I need to balance $ with performance, so i going to need a system that can handle a good VM system for my profession Hyperion Development, and has the power for my Professional Recording system protool 9.0.5
    these are the system i have looked
    Toshiba S855-S5254 I7-3610QM 15.6 4 Cores 2.3 Ghz 6 GB 640 GB 679.99 8421
    Asus A75VM-TB71 I7-3610Qm 17.3 4 Cores 2.3 Ghz 8 GB 750GB 799.00 8421
    Toshiba L775D-S7107 AMD A6-3420M 17.3 4 Cores 1.5 Ghz 4 GB 500 GB 409.99 2936
    Toshiba L775D-S7302 AMD A6-3400 17.3 4 Cores 1.4 Ghz G GB 640 GB 479.97 2935
    or is there something else that can handle my needs
    Please advise
    Roger H Hicks
    If you can afford it get something with a solid state drive (SSD).
    • deckofficer
      • Jun 2011
      • 7
      I'll 2nd that. 14 months ago I had V3 build a new desktop for me with (2) SSD's in a RAID 0. Computer boots quick and runs video editing programs that used to stall out my last PC. I also think a SSD for a laptop not only requires less power than a spinning HD, but can handle more physical abuse being solid state.
