How important is the graphics card for photo editing?
  • Nordavind
    • Oct 2012
    Hi all
    I just bought a new pc:
    -Intel quad core i5 3450 3.1 GHz socket 1155 Ivy Bridge (with integrated vga Intel HD2500)
    -mobo AsRock H77 PRO4/MVP
    -psu XFX Pro 550W
    -16gb ram Corsair Vengeance LP
    -HD WesternDigital Caviar Blue 500gb
    -windows 7 home premium 64 bit
    -Monitor: Dell U2412M 24'' 16:10 1920x1200px
    I just bought an economic dedicated video card, Sapphire Radeon HD6450 http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=917&pid=316&psn=&lid=1# because there was some problems with the integrated graphic card (Intel HD2500)
    I bought this card because I haven't much money, I hope this card it's good for photo editig. What do you think?
    My dilemma: how important is the graphics card for photo editing? I don't use my pc for gaming, I use it only for internet and photo editing 2D (= adobe photoshop cs6) not 3D
    Is HD 6450 a good vga for photoshop? In your opinion does a Radeon HD 6450 work fine with 24 megapixels files (Nikon D600)?
    Thanks in advance for your replies, I hope I can clarify this
    There are a number of functions in PhotoShop that are GPU accelerated.
    You can find a list of them here,
    http://forums.adobe.com/thread/979969
    It is also dependent on the O/S and video card used.
    Most of the functions in the list are things you aren't going to use all the time however. Plus the i5 3450 is plenty quick. So I think you'll only notice a small difference for photo editing I would think.
    You would, in my opinion, be better off spending the money on a fast Solid State Drive rather than a better video card. You'll notice the speed improvement of a SSD.
    The exception might be if you were editing truly massive images.
