Error Smart threshold exceeding condition detected .
  • Navin
    • Apr 2017
    I am running Disk and Video tests in Burnin application.
    Test is failing with the Error Smart threshold exceeding condition detected after 24 hr.
    But test is not giving the information that which smart attribute threshold value has exceeded.
    How can I find this information ?
    Navin
    It should be in the BurnInTest log. Likely it is bad sector count.
    • Navin
      • Apr 2017
      Hello David
      Burnin Test log is only saying that SMART Threshold exceeding condition detected.
      It does not have the information for which attribute SMART Threshold exceeding condition detected.
      Data from log file.
      DETAILED EVENT LOG
      LOG NOTE: 2018-03-06 19:38:08, Status, Activity event 56
      RESULT SUMMARY - INTERIM PERIODIC REPORT
      Test Start time: Tue Mar 06 14:58:08 2018
      Current time: Tue Mar 06 19:38:08 2018
      Test Duration: 004h 40m 00s
      Video Playback 546 16452 PASS 0 No errors
      Disk (C 3 1.287 Trillion PASS 0 No errors
      DETAILED EVENT LOG
      LOG NOTE: 2018-03-06 19:38:35, Disk, C, SMART Reallocated Sector Count start value: 167, current value 233
      SERIOUS: 2018-03-06 19:38:35, Disk, C:\BurnInTest test files\ SMART Threshold exceeding condition detected.
      LOG NOTE: 2018-03-06 19:38:41, Status, Test run stopped
      RESULT SUMMARY
      Test Stop time: Tue Mar 06 19:38:41 2018
      Test Duration: 004h 40m 33s
      Video Playback 547 16483 PASS 0 No errors
      Disk (C 4 1.296 Trillion FAIL 1 SMART Threshold exceeding condition detected.
      TEST RUN FAILED
      SERIOUS ERROR SUMMARY FOR THE LAST TEST RUN
      SERIOUS: 2018-03-06 19:38:35, Disk, SERIOUS: SMART Threshold exceeding condition detected. (x 1)
      Navin
        From the log,
        • Navin
          • Apr 2017
          Thanks David it was helpful
          Needed your support with the reproduction of Burn-in test failure:
          "Seek size requested not equal to actual"
          Attached the snippet of failure log.
          Queries:
          1. How the work load varies with cycle/time and we have observed different work load while test in progress
          2. If test fails what work load is going on that time, how can we find the work load
          3. For reproduction is there any way to run the same work load?
          4. What is the difference between Video playback and Disk(c: ) operations ??
          5. What does the error statement mean ?? What operation read/write returns this ??
          6. Burn-in log what does cycles and operations mean ??
          Thanks in Advance for your support
            The BurnInTest User' Guide answer most of these questions.
            https://www.passmark.com/ftp/BIT_Users_Guide_Ed9_0.pdf
            Also check you are using V9 and not some old release. Some old releases had bugs which have since been corrected.
            You also didn't attached the log.
            • Navin
              • Apr 2017
              Thanks David for your support.
              Now we are using Burnin 9.0 version.
              Using Burnin 9.0, we are running Network test (standard network test with internal loop back) with other test like Disk test, CPU test, 2D graphics test, RAM test and Video play.
              After 10-15 hour Burnin test is failing with packet receive time out error on running Network test.
              We checked it is happening because firewall gets start running.
              Before starting the test we had stopped firewall from services, but after some time it got enabled automatically and test got failed.
              We wanted to check whether any of the Burnin test enables the firewall which is causing the failure.
                No. BurnInTest doesn't turn the firewall on or off.
                Could it have been Windows update that ran overnight on your machine?
