What motherboard should i choose? am3+
  • Monte Cristo
    • Dec 2012
    • 25
    Hi David, i wanted to ask about motherboards. I am amd fan and i have hd 6870 and amd phenom 945. But my motherboard is crapy. I need am3+ motherboard that can do overclock to my cpu and gpu, can do sli ar crossfirex and support lots of ram. Could you suggest one that doesnt go above 200$ ?
    Should be no problem.
    Newegg for example sells about a dozen different AM3+ motherboards in the $100 to $200 range with at least 2 x PCI-E slots.
    Some examples,
    ASUS M5A99X EVO AM3+ AMD 990X
    GIGABYTE GA-990XA-UD3 AM3+ AMD 990X
    ASRock 990FX Extreme3 AM3+ AMD 990FX
