Water Cooling
  • Monte Cristo
    • Dec 2012
    • 25
    Water Cooling
    Hi David, wanted to ask about water cooling. Is it worth it? Or I will be better off with air cooling? Whats the best buget water cooling around the market?
    Thanks for super fast reply on my other posts
    We haven't done a comprehensive review of water cooling. So I am not the best person to ask.
    What I am sure of however is,
    A) It is more expensive that air cooling
    B) There are more things to go wrong with water cooling.
    C) Water and electricity don't mix well
    D) It only really makes sense in cases where you are doing serious overclocking
    • Monte Cristo
      • Dec 2012
      • 25
      So what good case and gpu cooler would you suggest?
        Bought a couple of the 'Antec Three Hundred Two' cases recently and they seem OK. There is no one case that suits everyone's needs however. If you are doing water cooling then you need to do some research into a suitable case.
        For GPU coolers I use the stock coolers. I'm not overclocking my GPU as it isn't required for most of the stuff I'm doing. You don't need anything special for a GPU if you are just doing EMail, browsing & coding.
