MemTest Errors
  • Jfwibberley
    • Nov 2018
    MemTest Errors
    Hi, I've been having trouble with my ram for a while now. I have hyperx fury ddr4 4x 8gb. I've run a memtest and I've got a load of errors but I don't understand what they mean. The ram I have is advertised to run at 2666 ( auto-overclocks). I think My issue is with the settings in bios, because if I lower the speed of the Ram I get less errors. But I don't know where to begin with voltages/ timings etc. Do I need to overclock my CPU in order for the ram to run at the advertised speed?
    Thanks a lot
    Here's my Memtest Report:
    EFI Specifications 2.60
    System
    Manufacturer System manufacturer
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 4024
    Release Date 09/07/2018
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name ROG STRIX B350-F GAMING
    Version Rev X.0x
    Serial Number 180118565500613
    CPU Type AMD Ryzen 7 2700X Eight-Core
    CPU Clock 3716 MHz [Turbo: 4368.9 MHz]
    # Logical Processors 16
    L1 Cache 16 x 96K (88810 MB/s)
    L2 Cache 16 x 512K (81345 MB/s)
    L3 Cache 1 x 16384K (31712 MB/s)
    Memory 32713M (17518 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-21300
    Kingston / KHX2666C16/8G / EC3B3C43
    16-18-18-39 / 2666 MHz / 1.200V
    DIMM Slot #1 8GB DDR4 XMP PC4-21300
    Kingston / KHX2666C16/8G / ED3B7543
    DIMM Slot #2 8GB DDR4 XMP PC4-21300
    Kingston / KHX2666C16/8G / CA3C4B0E
    DIMM Slot #3 8GB DDR4 XMP PC4-21300
    Kingston / KHX2666C16/8G / CF3C570E
    Result summary
    Test Start Time 2018-11-27 16:24:00
    Elapsed Time 7:09:07
    Memory Range Tested 0x0 - 81F380000 (33267MB)
    ECC Polling Enabled
    # Tests Passed 28/48 (58%)
    Lowest Error Address 0x6704B8EF0 (26372MB)
    Highest Error Address 0x6724B9710 (26404MB)
    Bits in Error Mask 0000000000001000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 6 [Block move, 64-byte blocks] 0/4 (0%) 20
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 19
    Test 8 [Random number sequence] 0/4 (0%) 20
    Test 9 [Modulo 20, ones & zeros] 0/4 (0%) 8
    Test 13 [Hammer test] 0/4 (0%) 18
    Last 10 Errors
    [Data Error] Test: 7, CPU: 13, Address: 6724B8ED4, Expected: FFFFEFFF, Actual: FFFFFFFF
    [Data Error] Test: 6, CPU: 13, Address: 6724B9710, Expected: FFFFFFFF, Actual: FFFFEFFF
    [Data Error] Test: 6, CPU: 13, Address: 6724B96F0, Expected: 00001800, Actual: 00000800
    [Data Error] Test: 6, CPU: 13, Address: 6724B8ED0, Expected: FFFFFFFF, Actual: FFFFEFFF
    [Data Error] Test: 6, CPU: 13, Address: 6704B9730, Expected: FFFFFFFF, Actual: FFFFEFFF
    [Data Error] Test: 6, CPU: 13, Address: 6704B9710, Expected: 00001800, Actual: 00000800
    [Data Error] Test: 6, CPU: 13, Address: 6704B8EF0, Expected: FFFFFFFF, Actual: FFFFEFFF
    [Data Error] Test: 7, CPU: 13, Address: 6724B8ED4, Expected: 00000100, Actual: 00001100
    RAM Errors normally means the RAM is bad.
    Overclocking doesn't make an unstable system more stable.
    See also this page
    • Jfwibberley
      • Nov 2018
      See also this page
      Hi, Thanks for the reply. I've had the ram replaced after getting errors with my old ram, but I'm still getting errors.
        All I can say is that your RAM errors, do in fact look like real RAM errors.
