I need help in assembling my own desktop (gaming)
  • sakshyamabc
    • Apr 2013
    Since assembled desktops are cheap,,
    what i have chosen
    cpu- amd fx-6300- 140$
    gpu- geforce gtx 560 Ti - 155$
    1. what motherboard do i need for these two components to fit and also mention price
    2. also cost of cheap RAM
    i really need it in cheapest possible price
    3. also will the cpu and gpu be able to play good games ?
    i need expert help
    You need a AM3+ motherboard. There are lots in the $50 USD range. For example.
    ASRock N68C-GS FX AM3
    GIGABYTE GA-78LMT-S2 AM3+ AMD 760G Micro ATX AMD Motherboard
    You might consider paying a bit more to get USB3.0.
    For RAM you'll need DDR3. It would be silly to get less than 8GB. So you probably want two sticks of 4GB DDR3 1600. Expect to pay $25 to $30 per stick.
    Have a look at Newegg for pricing.
    You'll be able to play pretty much any game. But not on the highest graphical settings.
    Also don't forget to buy a hard drive, case, power supply, DVD drive & heat sink if the CPU doesn't include one.
    • sakshyamabc
      • Apr 2013
      Thank You DAVID,
      i also need to know a good and cheap power supply can u plz mention the name
      and what about heat sink ?
        The gtx 560 Ti sucks down a lot of power. So you'll need a 550W+ PSU with 2 x 6 pin connectors. Don't pick the cheapest PSU. Expect to pay $60 - $100 USD. Consider Seasonic, Corsair, Antec, Rosewill, Silverstone.
        Unless you are overclocking, buy a boxed CPU with fan and heatsink included.
