CPU Baselines for a specific CPU?
  • ChipHanson
    • Jan 2019
    Your Last 5 Baseline report is invaluable, however, the fastest baselines drop off over time only to be replaced with substandard baselines/system configurations.
    Is there a way to view ALL baselines for a specific CPU...for instance if I wanted to see a list of all the baselines for an AMD 1800x.
    Thanks,
    ChipHanson
    Yes, you can do it in the PerformanceTest software.
