Test results showing 3000+ errors
  • FriendlyIntruder
    • May 2019
    • 17
    I'm just looking for some more information as to what these errors mean for my computer as a whole. Is my RAM or CPU bad kind of thing. If anyone can direct me to a source or let me know in a response I'd appreciate it. Let me know if you need any further information that I can provide!
    System Specs:
    • Operating System - Windows 10 Home 64-bit
    • CPU - AMD Ryzen 7
    • RAM - 32.0GB Dual-Channel Unknown @ 1066MHz (15-15-15-36)
    • Motherboard - Gigabyte Technology Co. Ltd. X470 AORUS GAMING 7 WIFI-CF (AM4)
    • Graphics - Dell S2716DG (2560x1440@144Hz) - 3071MB NVIDIA GeForce RTX 2080 Ti (Gigabyte)
    • Storage - 465GB Samsung SSD 850 EVO 500GB (SATA (SSD)) - 5589GB Seagate ST6000VX0023-2EF110 (SATA )
Name:	Memtest results.JPG
    Looks like bad RAM.
    See also
    • FriendlyIntruder
      • May 2019
      • 17
      If I identify which specific stick is bad, am I able to continue using my PC with 3 of the sticks while I RMA the fourth?
        Yes, most motherboards can support this. But they might drop out of dual channel mode, which will hurt performance. So 2 sticks might be better than 3, depending on how much RAM you required.
        • FriendlyIntruder
          • May 2019
          • 17
          From the results above you aren't able to tell which stick is faulty, correct? I would have to do the one stick at a time test to find errors?
            See,
