Intel DZ75ML-45K Motherboard
  • nagasahitya
    • Nov 2013
    • 10
    Intel DZ75ML-45K Motherboard vs Gigabyte GA-B75M-D3H Motherboard .which one is better in all aspects.
    They both
    - support the same CPUs
    - support the same amount of RAM
    - have PCI-E 3.0 slots
    - have USB3
    - have SATA 6Gb/s ports
    So really not much difference.
    The Intel board uses the Z75 chipset which is a bit better if you are going to overclock. For normal usage I would think the decision would depend on price & warranty.
    • nagasahitya
      • Nov 2013
      • 10
      when compared to the audio codecs,which one is better?
        Codecs are normally a software function, not a motherboard function.
        • nagasahitya
          • Nov 2013
          • 10
          i want a best & low cost mother board for my intel G2020.plz suggest.
            Cost and availability will depend on what country you are in.
            What is best will depend in your requirements. e.g. number of PCI-E slots required, full ATX board or microATX, overclocking requirements, video output ports needed, number of RAM slots, etc..
            A better approach would be to look at what socket 1155 boards are available from your preferred supplier, then compare the board spec with regards to what you need.
