Command line for USB3.0 Test
  • zmdismai
    • May 2020
    Is there any command line that I can use to run USB3.0 Test where I am able to set the Endpoint Type and Mode that I prefer?
    I saw Windows Console Application and I suppose it is the same as USB3.0 Test if we set the speed to USB3 but in this case, we are not able to customize the Endpoint Type and Mode right?
    There are no command line options to run USB3.0Test. However, the source code for the Windows Console Application in included in the download. If it doesn't fit your needs, you can modify it according to meet your testing requirements.
