Website question about Systems Benchmarked
  • Back-N-Black
    • May 2014
    Am I missing something, Is there some access to all the systems benchmarked? I see there are top 20 and bottom 20, where are all the ones in between? For example, i don't so much want to compare every component but would like to know what a Dell XPS Model number xyz's benchmark is.
    Thanks.
    Yes, you are missing something.
    You can access all the baseline files (hundreds of thousands of them) from within the PerformanceTest software, from the Baseline menu.
    • Back-N-Black
      • May 2014
      I see now, you access the baselines via the software program, not the website. trying to figure out how to see all my baselines at once now. Looks like I just save baseline from each computer and copy to my passmark baselines directory. Great.
        If the baselines have been uploaded, then there is also a summary available on our web site.
        For example.
        http://www.passmark.com/baselines/V8...id=23608031014
        http://www.passmark.com/baselines/V8...id=23587604332
        You get this URL upon uploading your results.
