vedio card is red and idk why
  • soheilimpious
    • Jul 2020
    hi guys , i installed the app like 7 days ago , now i see my gpu in red color in the main menu. is there any problem with it? im not sure it was red at the first days. how can i fix it if there is anything wrong with it? please help.
    No problem. All the best video cards are red.
    It makes them go faster
    Click image for larger version  Name:	palit-x1600pro-front.jpg Views:	0 Size:	134.6 KB ID:	48142
    • soheilimpious
      • Jul 2020
      SO I DONT NEED TO WORRY ABOUT ANYTHING RIGHT? and can you see my temp in the picture? its normal? im not doing anything with the pc at that temp.
        There is no (obvious) problem in the images you posted.
        Temps look OK. Remember that the 3D animation in PT10 uses some CPU & GPU time. So the machine isn't idle.
