Apples to Apples Comparison of Mobile CPUs and Desktop
  • superpowered
    • May 2014
    Hi there,
    I came across this old thread:
    http://www.passmark.com/forum/showth...PU-performance
    Given that smartphones/tablets now can do 64bit and SMID instructions as well -- what is best way to do an apples to apples comparison for these two tables:
    Apple MacBook Pro 15” - Intel Core i7-4740HQ
    Apple MacBook Pro 13” - Intel Core i5-4250U
    Asus Transformer Book T100TAZ2760 - Intel Atom Z2760
    HP Chromebook 11 - Samsung Exynos 5250
    Dell Latitude E7440 Touch - Intel Core i5 4300U
    Lenovo G580 - Intel Core i5-3210M
    Lenovo IdeaPad U430 Touch - Intel Core i5-4200U
    Lenovo ThinkPad X240 - Intel Core i5-4200U
    Acer Aspire E1-510P-2671 - Intel Celeron N2920
    MSI GS70 Stealth - Intel Core i7-4700MQ
    and
    Galaxy S5 - Snapdragon 801
    HTC One (M - Snapdragon 801
    iPhone 5s - Apple A7
    Nexus 5 - Snapdragon 800
    Moto X - Moto X8
    Moto G - Snapdragon 400
    LG G2 - Snapdragon 800
    Galaxy Note 3 - Snapdragon 800
    Thanks in advance.
    I think you mean, SIMD, not SMID.
    The Snapdragon 800 isn't 64bit and Android isn't 64bit either. Even for Apple, which does now have some 64bit support, it will be a while before it becomes more than a niche. SIMD support also isn't anywhere near as broad as x86 CPUs.
    The old thread is still valid in terms of how to do a comparison.
    But at some point, probably in the next 12 months, we are going to have to do a 64bit release for iOS and Android.
    • superpowered
      • May 2014
      Ah! Yes, you are correct. Thanks for clarification.
      For the CPUs I mentioned above, where on the site do I find:
      Integer Test
      Floating Point Test
      Prime Number Test
      String Sorting
      Compression Encryption
      This is for a blog post on differences between mobile and desktop CPUs -- more than happy to source PassMark in the post.
        We don't make the raw numbers available, but you can load baselines within PerformanceTest to see results for a particular baseline of a computer with that CPU type.
        The following numbers are averages from PerformanceTest V8 of variety of mobile CPUs as of 29/May/2014:
        Intel Core i7-4960HQ
        Integer Test ~153888 MOps/Sec
        Floating Point Test ~7058 MOps/Sec
        Prime Number Test ~43.2 Million Prime/Sec
        String Sorting ~6487 Thousand Strings/Sec
        Compression ~11340 KBytes/Sec
        Encryption ~1595 MBytes/Sec
        Intel Core i5-4300U
        Integer Test ~5788 MOps/Sec
        Floating Point Test ~2638 MOps/Sec
        Prime Number Test ~11.6 Million Prime/Sec
        String Sorting ~2660 Thousand Strings/Sec
        Compression ~4498 KBytes/Sec
        Encryption ~634 MBytes/Sec
        Intel Core i5-3210M
        Integer Test ~6005 MOps/Sec
        Floating Point Test ~2782 MOps/Sec
        Prime Number Test ~11.8 Million Prime/Sec
        String Sorting ~2776 Thousand Strings/Sec
        Compression ~4808 KBytes/Sec
        Encryption ~651 MBytes/Sec
        AMD A10-4600M
        Integer Test ~7239 MOps/Sec
        Floating Point Test ~2570 MOps/Sec
        Prime Number Test ~8.4 Million Prime/Sec
        String Sorting ~2528 Thousand Strings/Sec
        Compression ~4238 KBytes/Sec
        Encryption ~538 MBytes/Sec
        Intel Celeron N2920
        Integer Test ~4105 MOps/Sec
        Floating Point Test ~1242 MOps/Sec
        Prime Number Test ~3.7 Million Prime/Sec
        String Sorting ~1621 Thousand Strings/Sec
        Compression ~2084 KBytes/Sec
        Encryption ~311 MBytes/Sec
          The following numbers are averages:
          Samsung Galaxy S 5 (SM-G900F )
          Integer Test ~401 MOps/Sec
          Floating Point Test ~783 MOps/Sec
          Prime Number Test ~165 Thousand Prime/Sec
          String Sorting ~2541 Thousand Strings/Sec
          Compression ~2371 KBytes/Sec
          Encryption ~8.7 MBytes/Sec
          HTC One m8
          Integer Test ~382 MOps/Sec
          Floating Point Test ~750 MOps/Sec
          Prime Number Test ~161 Thousand Prime/Sec
          String Sorting ~2636 Thousand Strings/Sec
          Compression ~2753 KBytes/Sec
          Encryption ~9.4 MBytes/Sec
          Nexus 5
          Integer Test ~320 MOps/Sec
          Floating Point Test ~698 MOps/Sec
          Prime Number Test ~143 Thousand Prime/Sec
          String Sorting ~2177 Thousand Strings/Sec
          Compression ~1892 KBytes/Sec
          Encryption ~7.6 MBytes/Sec
          Moto X (XT105)
          Integer Test ~147 MOps/Sec
          Floating Point Test ~284 MOps/Sec
          Prime Number Test ~62 Thousand Prime/Sec
          String Sorting ~1037 Thousand Strings/Sec
          Compression ~1103 KBytes/Sec
          Encryption ~4.1 MBytes/Sec
          LG G2 (LG-D802 )
          Integer Test ~355 MOps/Sec
          Floating Point Test ~703 MOps/Sec
          Prime Number Test ~137 Thousand Prime/Sec
          String Sorting ~2217 Thousand Strings/Sec
          Compression ~1943 KBytes/Sec
          Encryption ~7.2 MBytes/Sec
