2000$ workstation Required !
  • Ahmed hafez
    • Sep 2020
    Hello guys
    i am building a workstation PC and i need some help here. the usage will be for 3dsMax, auto-cad, Photoshop, light room, revit, vray and corona render
    so please tell me your recommendation parts for the built dependingon your experience in the field
    because too much confused between the parts
    and which part should be higher the CPU or GPU ?!
    QUADRO or RTX
    BUDGET 2000$ USD
    Hello guys
    till now i got to recommended builds
    first option
    ryzen 9 3950x
    RTX 2060 super
    BeQuite Dark pro 4
    Asus tuf gaming x570 plus ( wifi )
    500gb nvme.m2
    1 tb ssd
    phanteks 400a
    700w psu
    16gb ram 3200
    second option
    ryzen 9 3900x
    RTX 2070 super
    BeQuite Dark pro 4
    500gb nvme.m2
    1 tb ssd
    phanteks 400a
    700w psu
    32gb ram 3600
    what is your recommendation also please ?!
    I would definitely go with 32GB of RAM.
    I hope you are going to use Ethernet for networking and not WiFi.
    Also what about a monitor (or dual monitors). I'd prefer a cheaper CPU/GPU, but great monitor and keyboard. But that is just my preference.
    I would have suggested the new 3080 video card, but it is probably too expensive for this build and sold out anyway.
