Automate BurnIn Test V9
  • visionmaxx
    • Oct 2020
    Dear Passmarkt Team,
    we are using your program in combination with a deployment server. Our problem is that we want to automate the activation process during the deployment and once it is activated, that it automatically starts the stresstest with our own config-file and we have a Custom BTICertificate.html too and when that is done, the program should be automatically uninstalled from the server.
    The deployment is only for servers and we install around two servers a week.
    Can you help us with that please? Maybe a Powershell script or something else?
    Thank you in Advance!
    I just checked and it seems VisionmaxX only has a single license (for a single machine at a time). So automation shouldn't be required?
    • visionmaxx
      • Oct 2020
      Hi David,
      Thank you for the Answer!
      Yes we have single machine license at a time, and we install only 2 Servers a week, and we need that automation because we want to put the server on deployment install for 24 hours and doing nothing on them until is finished. After that we unistall the BurnIn Test software from server.
      "Frequently Asked Questions (FAQ)
      You need 1 license per machine that is running the software, or has the software installed at the same time."
      We use only one machine beacuse we have only one license and we don't need more licenses.
      Can you support us ?
      Thank you in Advanced.
        If you place a key.dat file, a text file with the your username & key information (copy/pasted the same as if you were registering normally), in the same directory as the installed BurnInTest executable then it will use this key when starting instead of having to paste the key in when running each time.
        You could also use the "Install to USB" option from the file menu to run directly off a USB drive.
