Intel® Xeon® E5-4607 v2 2.6GHz is not in cpu mark chart
  • DEAIME
    • Nov 2014
    HI,
    I'm looking for Intel® Xeon® E5-4607 v2 2.6GHz to see the ranking in the CPU mark but is not in the list
    How to fing the ranking points for this processor?
    Can you add this to the list
    It doesn't look like we have any results for the E5-4607 V2 as yet. Which generally means it is both rare and expensive.
    Maybe check back in a month or so. We get about 500 new results come in every day. So it might eventually show up.
    • DEAIME
      • Nov 2014
      Hi David,
      Thank you for your answer, but it is any possibility to evaluate E5-4607 V2, because we need this evaluation to an urgent issue.
      I don't know exatly the procedure of entering a processor to the list, but if is any possibility to have points for this procesor, will be very helpful to us
      Best regards
        If you wanted to buy us one, or have one yourself, then you can test it and submit the result.
