memtest86 errors
  • valentin
    • Oct 2021
    memtest86 errors
    hello, tell me where can I find out (decipher) the errors that appeared in MemTest86? 1) test: 6 addr: 174352090 expected: 00000404 actual: 00000400 cpu: 0 2) 6 / 1743520D0 / 00000804 / 00000800 3) 6 / 174352150 / 00002004 / 00002000 4) 6 / 176352070 / 00000404 / 00000400 5) 1763520B0 / 00000804 / 00000800 6) 6 / 176352130 / 00002004 / 00002000
    • 336
    The data read from the RAM doesn't match the data written to the RAM. So likely the RAM is bad.
    Assuming if you are asking which stick of RAM has the errors, you would need to test each stick separately.
    Start with this page for more on troubleshooting:
    • valentin
      • Oct 2021
      thanks Simon, you helped me a lot
