benchmark methodology
  • joloughlin
    • Jan 2015
    All,
    Does passmark follow a similar method to SPEC when calculating the aggregate score?
    So, take the execution time of a set of benchmarks, normalise against a reference machine and then take the geometric mean?
    Regards
    John
    You can find the formula here.
    http://www.passmark.com/forum/showth...-and-disk-mark
    It is for the most part a Constant * Weighted Harmonic Mean. With the constants being determined from a average result of several reference machines.
    Also our execution times are constant. The number of operations completed in a constant period are used to determine performance.
