Memtest86 inform error Test: 8 Addr
  • thanhduong001094
    • Dec 2021
    Please help me! I used two memory Gskill 8G buss 2666, when using Memtest86 software then it informs error for me as image attached! I tried to check one by one with both memory by Memtest86 then the both it ok, not issue!
    Thanks !
    Some errors only appear in dual channel mode.
    Do you have a spare pair of RAM sticks to try?
    • thanhduong001094
      • Dec 2021
      I will try it and inform you later.
      Thanks to support me!
      • thanhduong001094
        • Dec 2021
        Hi David,
        I don't have other memory to change but I bought a hard drive SSD 256G change for the old hard drive SSD 120G and set up new Windows. Surprise, the problem was resolved!
        Can you explain for me to understand better?
          Probably just good luck or co-incidence.
          (e.g. problem only happens at certain temperature, or maybe EMI effect)
          Or maybe re-reseating the sticks cleaned the connectors.
