USB-PD Tester Model 125 - Feature Request
  • pbrooks100
    • Jul 2022
    I intend to connect multiple PM125 devices to my test setup.
    I will use the serial number to identify which PM125 is connected to a specific port.
    There is no label attached or any way to view the SN of the PM125.
    Please add a field / display item on LCD to show the electronic SN and/or firmware (Other Settings)?
    You can get the serial number from the free Window's app.
    See example below.
    If you have a number of units, you could just make yourself a label for the front of the unit.
