management console timing to IST from there original coded time zone
  • Sai Prasad P.B.N.V
    • Nov 2022
    trying to change the timing to IST but after the code change their issue persists and the timing is not showing just it's showing default something
    • 336
    Note we do not provide support for modifications to our code and that the timezone code in the console is currently only intended for use with the cloud version of Management Console.
    You should move the date_default_timezone_set function outside the if statements, as the perpetual version does not generate a cookie for the console to read and hence the function does not run.
    Or instead change the timezone in the php.ini file:
    https://www.php.net/manual/en/dateti....date.timezone
    Also make sure that machines connecting to the console have their time/timezone correctly set.
