Wix
  • svaughn01
    • Mar 2023
    Wix
    Hello, before I purchase this software I'm just wondering if anyone has got this software to work with the Wix website builder? Thanks
    It is unclear which software of ours you are referring to. I will hazard a guess and assume you are referring to our Zoom Search Engine application.
    We have not had any experience with Wix, but a quick search seems to indicate it is a WYSIWYG type of web development platform. Wix seems to limit what can be uploaded and the only scripting they allow is some JavaScript. In order to use our search solution is to upload our set of search files to your website. We do offer JavaScript as a search option, so there might be some chance it works, but we cannot confirm. But the easiest way to determine if it will is to try it. You can use our free edition to test.​
    • svaughn01
      • Mar 2023
      Thank you for the response and yes that is the software I am referring to.
