Location of .cfg files
  • Dilbert
    • Sep 2006
    Is there anyway to setup the tool so that when the program is envoked, it defaults to a particular test directory and not the default "burnintest" directory?
    You can specify a configuration file on the command line, with the -C
    command line option. There is no restriction on the directory the
    configuration file is located in.
    So for example you can run BurnInTest like this,
    "C:\Program Files\BurnInTest\bit.exe" -C E:\LastUsed.bitcfg
